Is there a way to use a pallette or macro to set the intensity for a level so,
for example u can press group 3 - all Parcans
then press the other button to set them to full,
Thanks Cdexter
Hi Cdexter,
On the LeapFrog 48&96 there is no way to record intensities into a palette.
However, you can select a group, and then use the 'Intensity' option on the wheels to change the intensity of them all at the same time.
Jon Hole
