I have 4 egg strobes plugged into our dimmers, and have used the Demux unit to set then channels to 'switch' mode as they cannot be dimmed. However, when the strobes are in the dimmers, they are constantly on and I cannot control them through the desk.
Would there we a slight amount of constant power through the dimmer racks?
Hi
maybe the dimmer - chans are on preheat
Have a look onto your dimmer´s maybe they have a switch function too...
switch both units to "switch" Demux and Dimmer.
There must be a small amount of power as you figured in your post:
Just measure it to be sure 8O 8)
Sebastian H.
Pro - Sound Showtechnik
Albert Einstein
Al Capone
Hey NZ,
I have never heard about phantom power on a dimming unit
there is only +48V phantom power on these pocketfull of quiet
soundmixing consoles to feed hungry DI´s or mics *lol* :D
What happens to fixtures when we feed them with these adittional +48V
unfortunally of another phase :twisted:
Sebastian H.
Albert Einstein
Al Capone
hi everybody
just add a pinspot or similar to the same channel. some dimmers (which btw sometimes don't like strobes) need a regular lamp to dim for the range between 0 and abount 8%. it can be a pinspot, a par30, just some normal tungsten generic.
greetz
felix
indeed, I am sure this will work fine
If there is resistivity of a pinspot or similar then the phantom power would drain to these lamp and your egg strobe should work fine.
Compliments to Felix ...
Sebastian H.
Albert Einstein
Al Capone
