succa20 Posted September 12, 2012 Report Share Posted September 12, 2012 I,ve got a jester ml24 to repair.All LEDs light up when switched on pse help. Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted September 13, 2012 Report Share Posted September 13, 2012 Hi Succa20, What is the LCD display saying? Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
succa20 Posted September 16, 2012 Author Report Share Posted September 16, 2012 LCD only background light on no message Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted September 16, 2012 Report Share Posted September 16, 2012 First port of call would be to follow these instructions to replace the internal battery: http://zero88.com/support/index.php?/Knowledgebase/Article/View/507/0/error-bad-product-id Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
succa20 Posted September 17, 2012 Author Report Share Posted September 17, 2012 How to do a full reset of the console Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted September 18, 2012 Report Share Posted September 18, 2012 go into SETUP / Super User (SHIFT + MODE), and then use the down arrow to select the option saying 'Reset Desk'. Press Enter. Select 'Yes' Press Enter. Regards, Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
succa20 Posted September 19, 2012 Author Report Share Posted September 19, 2012 1.I tried to do as you said using the instruction on the link you gave,for info the console is still not displaying anything on the LCD screen all LEDs are on.I removed the internal battery and insert it againSituation still the same i.e all LEDs on. 2. Another ML24 console a good one has the shift switch stuck and we have to give small taps on it several times for it to work.Can I change the switch,if yes can you give me the description of the switch so that I can buy one pse. Thanks Quote Link to comment Share on other sites More sharing options...
KWR88 Posted September 20, 2012 Report Share Posted September 20, 2012 please can you PM on the address below to take this further. If you could give me both the serial numbers for the desk so we can date the firmware and hardware they are using. Quote Regards, Keith Rogers keith.rogers@signify.com DD: +44 (0) 1633 833 101. Link to comment Share on other sites More sharing options...
succa20 Posted September 22, 2012 Author Report Share Posted September 22, 2012 Ok Thanks will do as needed Quote Link to comment Share on other sites More sharing options...
succa20 Posted September 24, 2012 Author Report Share Posted September 24, 2012 ZERO88 jesterml24 qty 2 1.sno. 0011400 08100003(good one only some switches stuck on use) 2.sno. 0011400 07490024(all LEDs on no display ) Quote Link to comment Share on other sites More sharing options...
