go into SETUP / Super User (SHIFT + MODE), and then use the down arrow to select the option saying 'Reset Desk'.
Press Enter.
Select 'Yes'
Press Enter.
Jon Hole
1.I tried to do as you said using the instruction on the link you gave,for info the console is still not displaying anything on the LCD screen all LEDs are on.I removed the internal battery and insert it againSituation still the same i.e all LEDs on.
2. Another ML24 console a good one has the shift switch stuck and we have to give small taps on it several times for it to work.Can I change the switch,if yes can you give me the description of the switch so that I can buy one pse.
Thanks
please can you PM on the address below to take this further.
If you could give me both the serial numbers for the desk so we can date the firmware and hardware they are using.
Keith Rogers
