Hi,
I just bought a Jester ML 48 and I've two problems:
1. I can't update the fixture Library throught USB
2. I have the following error message when I try to assign a new fixture (importing from USB)
" NO FIXTURE MANF DATA" I've created the Fixture type (on USB) with latest version 2.6.0.0 of Fixture type editor. I've attached the test.ift file.
Thanks in advance for your help!
test.iftFetching info...
Just tried your file with the latest Phantom Jester ML and it works fine. Loads the Showtec Multibeam without any problem.
Where did you purchased your Jester ML48? Did you called your local dealer for support?
