chrisbo Posted August 22, 2012 Report Posted August 22, 2012 I'm I right in assuming that once 2 desks are connected as master/slave you use the memorybank of the master desk and the slave desk are "just" 24 extra channels giving a total of 48 channels . I know from a previous question that both desks need to have a dmx module and need to be both connected if dmx is to be used . There is very little to find on master/slave usage on the internet ( or the manual of the sirius24 ) Thank you Quote
KWR88 Posted August 24, 2012 Report Posted August 24, 2012 It has been a while since i used one of these in this mode, but If I remember correctly as you said the DMX out is sperate so you have to run a feed from each desk into the dimmers. It is possible softpatch the second desk an use a merge if require. You then program each desk speratley, but when you connect them together to play back, a go push on the master drives the slave as well. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
