labby Posted August 21, 2012 Report Share Posted August 21, 2012 Hi guys, i am trying to set up a show on the go button but when i programe a memory it wont let me adjust the fixtures for the next memory. it seem to be only the dimmer racks that are affected,and i am unable to reduce the brightness of any of the cans connected to the dimmers. i have tried everything i could think of but to no avail. i have also looked through the threads on here but with no luck.im using a leapfrog 96 with 7.4 software installed and the latest fixture library. any help would be appreciated. thanks in advance. Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted August 22, 2012 Report Share Posted August 22, 2012 Hi Labby, Are you programming in tracking or non tracking mode? Are you programming from the channel faders, or from the submasters? Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
labby Posted August 22, 2012 Author Report Share Posted August 22, 2012 im in non tracking mode and it is the channel faders that are the problem. i have a dimmer rack patched to the first six faders and these are the ones giving me the problem Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted August 24, 2012 Report Share Posted August 24, 2012 Are you familiar with 'catching' the channels? It means you have to take the fader to (or above) the value that channel is currently on. So if the channel is at 78%, and you want it to be at 50%, you have to take the channel fader up to at least 78%, and then back down to 50% Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
labby Posted August 24, 2012 Author Report Share Posted August 24, 2012 i tried to catch the channels but still no luck. this is so frustrating Quote Link to comment Share on other sites More sharing options...
Franck Posted August 27, 2012 Report Share Posted August 27, 2012 Do you use the CLEAR button? Just tried what you described and it works perfectly fine in both tracking and non-tracking. Please explain step by step how you do stuff. Quote Link to comment Share on other sites More sharing options...
