Kirkup_xp Posted February 3, 2004 Report Posted February 3, 2004 Could you please confirm whether the playback speed pot takes one value as its normalised position, or a range. When I use the test mode, there seems to be a range between which the pot is "clicked" into the middle. Obviously this should be replicated within the software - can you confirm if it is or not? I appreciate its a small niggle, but should be quite easy to fix, if indeed it is a problem. If the desk does take one value, can you tell me which value, so I know where the pot should rest. Ta Peter Quote Peter Kirkup
Simon Posted February 4, 2004 Report Posted February 4, 2004 The normal position is a range of values. When the desk software is running, if the LEDs either side of the pot are both off, the pot is in the normal position. Quote Simon Aspland
Kirkup_xp Posted February 4, 2004 Author Report Posted February 4, 2004 Thanks Simon. I had thought it would be that, but wanted to check. Quote Peter Kirkup
