pierotec Posted August 3, 2012 Report Posted August 3, 2012 Hi, can be convert a simple cue list with only dimmer channels by Compulite Spark to Frog2 Thanks Piero Quote
Franck Posted August 6, 2012 Report Posted August 6, 2012 Hi Piero, Do you have an ASCII Show file from your Compulite? Thanks Franck Quote
pierotec Posted August 7, 2012 Author Report Posted August 7, 2012 I have given this files......??? files Memorie Spark.zip Quote
Franck Posted August 7, 2012 Report Posted August 7, 2012 Not sure what your file type is but that is not ASCII. Looks like a Compulite file. Sorry that will not work. Quote
Kirkup_xp Posted August 7, 2012 Report Posted August 7, 2012 Hi Piero There's a utility on the Compulite website to convert from Spark (or any 4D) showfiles into ASCII. This outputs with a file .cpl - if you rename this to .txt, you can import them into ZerOS. However, there appears to be a problem bringing those files into Version 7.4 of ZerOS - i've just tried the whole process here and it's giving me some errors, which we'll need to fix. I'll let you know once these are fixed, and we can export a show file for you. I've attached the converted ASCII files to this message, incase those are helpful to you (you can view them in Notepad or any text editor). Peter Quote Peter Kirkup
Kirkup_xp Posted August 8, 2012 Report Posted August 8, 2012 Hi Piero We've now resolved this issue. It turned out to be a small bug in the Compulite tool - they don't add a carriage return after the end of the ENDDATA in the ASCII file, which the file format requires. We've fixed these files for you, so you should be able to load them into ZerOS. In the next version of ZerOS, we will be tollerant of this requirement for the carriage return, so you won't see this problem. You should be aware that in the show files, the Compulite tool has added a 4 second delay time to almost every fade up time on the show file - this might have been in the original file, but it seems unlikely. You can see this in the text file: CUE 4.2 UP 4.0 , 4.0 DOWN 0.0 , 0.0 You may want to perform a find and replace on this file, to remove these delay times - you can do this in Notepad or any other text editor. FIND UP 4.0 , 4.0 REPLACE WITH UP 4.0 , 0.0 Hope this helps, Peter Compulite Files Converted.zip Quote Peter Kirkup
pierotec Posted August 8, 2012 Author Report Posted August 8, 2012 Very very thanks, Peter and Franck. Zero88 the best. Piero Quote
Franck Posted August 8, 2012 Report Posted August 8, 2012 Thanks Piero. Have a look at our Me and My Zero 88 Photo Competition. You can win a free Zero 88 Lighting Console! www.zero88.com/mamz88 Quote
pierotec Posted March 7, 2013 Author Report Posted March 7, 2013 Hi, how can I open an ascii file or txt on frog2. when it is loaded only displays the list cue, with the crossfade time, triggers etc.. but no patch channel. Piero Quote
