Linkin 2 Sirius 24
The manual states that there is (was) a 8pin din cable to link 2 desks . I assumme these are no longer available . Is it possible to make one myself and how's the pinout .
Also , is it always possible to fit a dmx module to these desk ? I'm thinkin of buying another one but it has no dmx build in ( I have a spare module on the shelf ) .
Thanks
yes you can make one of these pretty easily, the wiring config is in the rear of the manual, if you can't find it PM me on the address below.
For the DMX module, the original MK1 desk could not be fited with a DMX card, you can tell the differecne between a Mk1 and Mk2 as the MK1 will not have the memory card slot on the rear panel.
All Mk2 could take a card but some of the early units required a modification to fit the card, and if you are planning on linking them you will also need this as well. This was all in DMX card kits, again i can give you the info if needed.
Keith Rogers
