Martin Sound Service Posted July 29, 2012 Report Share Posted July 29, 2012 Hey, I recently purchase a second hand Frog Mamba desk. I will use this desk for school gigs. I already programmed scenes en chases under the faders and the SX bottons. I would like to control the lights by opening one fader and adding other faders and SX buttons. Now when i want to do this only the last activated chase, scene is outputting. Can this desk do this and if yes how. I guess it has something to do with the LPT and HTP settings. But I cant find much info in the manual. Desk configuration is mainly default. I other problem i have. When I set the time/date after rebooting the desk time and date are lost. Battery check says OK Thanks, Martin Quote Link to comment Share on other sites More sharing options...
Franck Posted July 30, 2012 Report Share Posted July 30, 2012 What software version do you run? Do you program in partial or full mode? What serial number has your Mambo Frog? Quote Link to comment Share on other sites More sharing options...
Martin Sound Service Posted July 30, 2012 Author Report Share Posted July 30, 2012 SN: 0073901 XXXXXXXX SW: 10.4.1 BIOS: 5.3.1 I try both, full and partial. When i put different data form different fixtures, under different SX or Submasters each time i change the SX or Submaster output the previous output goes to zero. The config of the desk is for the rest default but i also played around with different setting but no success. Quote Link to comment Share on other sites More sharing options...
Franck Posted July 31, 2012 Report Share Posted July 31, 2012 Please update to the latest software 10.12: http://zero88.com/support/index.php?/Knowledgebase/List/Index/255/software Download the English manual here: http://zero88.com/support/index.php?/Knowledgebase/Article/View/51/74/frog-range-operating-manual-issue-6-en Please read through this: Partial Data, Tagging Fixtures... from 4-4 (page 28) Quote Link to comment Share on other sites More sharing options...
Martin Sound Service Posted July 31, 2012 Author Report Share Posted July 31, 2012 Hi Frank, Thank you for the support. Try to update the desk: I reboot the desk with the floppy in and the OS copy on it. desk reboot and os is loading then this message: Desk ID is Invalid Serial number not recognized Startup halted I also downloaded the manual and will be busy with it tonight. Quote Link to comment Share on other sites More sharing options...
KWR88 Posted July 31, 2012 Report Share Posted July 31, 2012 Think you may have also e-mailed me direct as well, if not it, sounds like you have an issue with the desks battery. It may not be flat but it may be have gone blow the threshold for being able to hold the settings. I would replace this first then carry out a reset desk to defaults from super user, to clear any corruption that this has caused. Battery type is a CR2032 coin cell battery. If you need any further help please contact me directly on the address below. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
Martin Sound Service Posted August 4, 2012 Author Report Share Posted August 4, 2012 Hi everone, - I changed the intern batt - reset the desk to default - install the new software program mode in partial and then just a question of tagging and untagging the fixture when creating scenes and chases. Thanks for the support, you was a great help. Quote Link to comment Share on other sites More sharing options...
Franck Posted August 6, 2012 Report Share Posted August 6, 2012 Thanks for your feedback Martin. Let us know if you have any other questions. Franck Quote Link to comment Share on other sites More sharing options...
