awillimont Posted June 22, 2012 Report Posted June 22, 2012 I load a memory and then go to the program window, it'll let me adjust any memory currently at 0 with the relevant fader but if the value is above 0 I can't change it. All advice gratefully recieved. A Quote
awillimont Posted June 22, 2012 Author Report Posted June 22, 2012 Ok after some more experimenting it seems that I can increase the level with the fader but not decrease it, I used to be able to select the channel, hit enter and input a value with the keyboard. Has this functionality gone? If so how does one decrease the level of a channel? Quote
Jon Hole Posted June 23, 2012 Report Posted June 23, 2012 Have you got the Leap Frog 48 or 96, with USB, or the Leap Frog with Floppy Disk drive? On the Leap Frog 48 & 96, you have to 'catch' the channel by taking the channel's fader to the percentage that it's at, and then you can take the channel to whatever percentage you require. So, If the fader i at 0%, but the channel is actually at 50%, and you want it at 30%m you have to take the fader to 50% or above, and then back down to 30%. If this isn't quite your problem - please email me your show file to the address in my signature below. Hope that helps, Quote Jon Hole linkedin.com/in/jonhole
awillimont Posted June 23, 2012 Author Report Posted June 23, 2012 It's a leapfrog 96 with USB, I recently upgraded from OS 5.3 if I try and catch a channel it will let me increase the value but won't drop below the programmed value already there. With 5.3 I could load a scene into the program window and then select channels and type a value. Is this functionality no longer available? I'll send you my show file on Monday. Many thanks Alistair Quote
awillimont Posted June 25, 2012 Author Report Posted June 25, 2012 After reseting the desk catching now seems to work, it woiuld seem my showfile was causing issues. I assume that typing the value for a channel is no longer supported? When I first started the desk and opened the program and memories windows, they displayed half screen so you could see both. if I close them and re-open them they are full screen, how does one get them half screen? cheers A Quote
