HPCTechnical Posted June 8, 2012 Report Posted June 8, 2012 Hi, is it possible to use Chilli HF dimmers in 'mixed' formation - specifically, on a 4-channel dimmer, using one channel as a switch for non-dimmable LEDs, and the remaining 3 channels as conventional dimmers for tungsten sources? Cheers, Quote
Jon Hole Posted June 8, 2012 Report Posted June 8, 2012 Hi, The Chilli HF isn't a conventional dimmer, so this isn't possible. Each channel consist of a relay and a low voltage output that can be globally set as either 0-10v or DSI . Best Regards Quote Jon Hole linkedin.com/in/jonhole
HPCTechnical Posted June 8, 2012 Author Report Posted June 8, 2012 Thanks Jon, We only need one channel of swtiched output for the LEDs, and the waste of the 7 other channels (we have 2 x 4-channel HF racks) offends me! If I were to swap them for i variants, is there a single channel product you do that would work with ChilliNet and DMX, or would it be a cse of reusing one of the Chilli 4s? Quote
Jon Hole Posted June 11, 2012 Report Posted June 11, 2012 We don't have individual channel products unfortunately, so you'll have to use one of the 4 channel HF Chillis Quote Jon Hole linkedin.com/in/jonhole
HPCTechnical Posted June 11, 2012 Author Report Posted June 11, 2012 Many thanks, Jon, your help much appreciated Quote
