Hi all,
Ive tried to create fixture files for the following :
Lanta Fireball Par 64 Quad
Stairville LED 252 RGB DMX Bar
When I try to upload the file to a Jester ML48 desk it loads to 90% and then says 'wrong file type'. Any suggestions?!
Thanks in advance, Nik.
Penrice.ift
They seem to load into the desk I have here with out any issues.
How are you trying to load these onto the desk?
The only time you will see that message is if you are trying to update the main fixtuer library with a user created file.
To load these files into the desk you go to assign fixture, select add fixture, then select either user fixture or USB as the source from the multi function buttons.
If you do not see these options then may be runing an older version of the OS.
Please PM on the address below with the desk serial number and OS version to take this further.
Keith Rogers
My apologies - I was doing it wrong... Your suggestion above was correct. I'm new to the desk!
I'll test the files on the rig tomorrow, and if they are OK i'll let you know so you can add them to the library.
Cheers for the swift response.
Nik.
