lightning77 Posted June 4, 2012 Report Posted June 4, 2012 Hey kind people at Cooper Controls, I have a Bullfrog and am unable to get any output from Universe B. The patching is all fine, ie some on A and some on B, and the desk (output monitor) indicates that signal is being sent to both Universes, however there is no actual output from the B universe. I tested the generics on B by just swapping the dmx cables around A>B, B>A and when patched to A they work fine so it's not a lamp issue. Is there a way do activate/deactivate universe B, or am i just having a blonde moment and missing something.....? many thanks in advance Quote
KWR88 Posted June 6, 2012 Report Posted June 6, 2012 hi, No there is no way of turning the universe on or off it is always on and outputting a signal. Is the green LED next to the socket on? If you can pm on the address below with the answer and the desk serial number so I can date the hardware I can help you further from there. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
