jrphs Posted May 13, 2012 Report Posted May 13, 2012 Hi Does anybody have a fixture file for Futurelight PHS-150 Moving Light? If not ill have a go at making one! Its for a Fat Frog board. Many Thanks Jack Quote
Jon Hole Posted May 14, 2012 Report Posted May 14, 2012 Hi Jack, Do you have the DMX breakdown for the PHS-150? I can't find one online. Best Regards, Quote Jon Hole Global Product Manager, Systems and Control
jrphs Posted May 14, 2012 Author Report Posted May 14, 2012 Hi, I have the manual, which says: Control-channel 1 - Horizontal movement (Pan) Control-channel 2 - Vertical movement (Tilt) Control-channel 3 - Pan/Tilt-speed Control-channel 4 - Colour Wheel Control Channel 5 - Static gobo-wheel,gobo shake Control channel 6 - Rotating gobo index,gobo rotation Control channel 7 - Shutter, strobe Control channel 8 - Switching the lamp, Reset, Internal programs Contol channel 9 - Pan-movement with 16bit-resolution Contol channel 10 - Tilt-movement with 16bit-resolution Many Thanks Jack Quote
Jon Hole Posted May 14, 2012 Report Posted May 14, 2012 Does it have any more information than this? Would it be possible to either fax it or email it through to me? All my details are in my signature Regards, Quote Jon Hole Global Product Manager, Systems and Control
jrphs Posted May 14, 2012 Author Report Posted May 14, 2012 Just emailed the manual over to you. Thanks Jack I can't seem to send it you via email, my message keeps getting returned to me when I try and email you. Is the a alternative address I could use? Thanks Quote
Jon Hole Posted May 14, 2012 Report Posted May 14, 2012 Hi, Sorry you had problems emailing me - I think my inbox might have been full. Please try emailing it to jon.hole@cooperindustries.com again. If that doesn't work, try support@zero88.com Best Regards, Quote Jon Hole Global Product Manager, Systems and Control
jrphs Posted May 14, 2012 Author Report Posted May 14, 2012 Hopefully it has got to you now. Thanks Jack Quote
