mattdyas Posted May 7, 2012 Report Share Posted May 7, 2012 hi all i have come across a strange problem with the leap frog, for some reason when programming LED lighting into subs they fade up but not down. so there on full till 5% which is trigger level and then off any suggestions why the desk has suddenly decided to do that. thank you Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted May 7, 2012 Report Share Posted May 7, 2012 Hi Mattdyas, Which fixture did you use in the fixture library to patch your LEDs? Regards, Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
mattdyas Posted May 7, 2012 Author Report Share Posted May 7, 2012 yer i patched in in RGB dimmer (3channel) and also had to create a fixture type for our other fixture all palets set not to virtual dimmer Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted May 7, 2012 Report Share Posted May 7, 2012 If there's no virtual dimmer, than they won't dim with the submasters. An option is to double click in the 'comments' section of that Submaster, click on 'Submaster Controls...' and then select 'Colour'. However, I would strongly suggest repatching them with a virtual dimmer, so they then fade with your normal intensity fades, and they will respond to the Grand Master, Blackout etc etc Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
