BassTool Posted April 12, 2012 Report Share Posted April 12, 2012 Is there a 3D software programme compatible with the Jester where we could create our show on a PC screen by mimicking our fixtures and positions in a 3D view complete with the correct footprint size of our show? ie back truss and front truss and same spacings of fixtures etc? http://www.thedustytools.com/13.html Scroll to the bottom to see our set up. Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted April 13, 2012 Report Share Posted April 13, 2012 Hi There BassTool, There are a number of 3D simulation software packages out there - most of them offer a DMX Input box which you can feed the DMX Output from your Jester ML24 into, to mimic the behaviour of the lights on stage. If those packages don't support a DMX Input box, you can use a DMX-Ethernet box (like our 1 Universe Ethernet Box) to convert the physical DMX into Ethernet signals, which the simulation software can then use to determine the look on stage. Check out: www.cast-soft.com www.capturesweden.com I hope this helps, Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
BassTool Posted April 14, 2012 Author Report Share Posted April 14, 2012 Hi There BassTool, There are a number of 3D simulation software packages out there - most of them offer a DMX Input box which you can feed the DMX Output from your Jester ML24 into, to mimic the behaviour of the lights on stage. If those packages don't support a DMX Input box, you can use a DMX-Ethernet box (like our 1 Universe Ethernet Box) to convert the physical DMX into Ethernet signals, which the simulation software can then use to determine the look on stage. Check out: www.cast-soft.com www.capturesweden.com I hope this helps, Peter Thanks for that Peter! Quote Link to comment Share on other sites More sharing options...
