BassTool Posted April 12, 2012 Report Posted April 12, 2012 Is there a 3D software programme compatible with the Jester where we could create our show on a PC screen by mimicking our fixtures and positions in a 3D view complete with the correct footprint size of our show? ie back truss and front truss and same spacings of fixtures etc? http://www.thedustytools.com/13.html Scroll to the bottom to see our set up. Quote
Kirkup_xp Posted April 13, 2012 Report Posted April 13, 2012 Hi There BassTool, There are a number of 3D simulation software packages out there - most of them offer a DMX Input box which you can feed the DMX Output from your Jester ML24 into, to mimic the behaviour of the lights on stage. If those packages don't support a DMX Input box, you can use a DMX-Ethernet box (like our 1 Universe Ethernet Box) to convert the physical DMX into Ethernet signals, which the simulation software can then use to determine the look on stage. Check out: www.cast-soft.com www.capturesweden.com I hope this helps, Peter Quote Peter Kirkup
BassTool Posted April 14, 2012 Author Report Posted April 14, 2012 Hi There BassTool, There are a number of 3D simulation software packages out there - most of them offer a DMX Input box which you can feed the DMX Output from your Jester ML24 into, to mimic the behaviour of the lights on stage. If those packages don't support a DMX Input box, you can use a DMX-Ethernet box (like our 1 Universe Ethernet Box) to convert the physical DMX into Ethernet signals, which the simulation software can then use to determine the look on stage. Check out: www.cast-soft.com www.capturesweden.com I hope this helps, Peter Thanks for that Peter! Quote
