Hi Steve,
Are you wanting to use it in 3ch, 4ch or 6ch mode?
If you are happy with just 3 channels (Red, Green, Blue) then you can use the 'RGB Dimmer' within 'Standard Fixtures'.
Jon Hole
Morning,
Hi, Yes it'll just be using the 3CH mode, however from checking that fixture in your editor doesn't it use a 4th channel for the dimmer part? Or is that virtual?
Many thanks.
Steve
Hi Steve,
Ah nevermind last post, just checked in the Editor and it's virtual :) Thanks a lot. Will try it out on monday.
Steve
Hi Steve,
Yes your right - the 'RGB Dimmer' is 3 channels plus a virtual dimmer. The 'RGB+D' is the equivalent 4 channel profile.
Jon Hole
