Hi all,
I've used my Frog2 with a clean install 7.2.1 but when I click a function key like STACK on the command line I read STACK 3.
So if I click a function key it clicks the 3 on numeric keypad automatically.
I've installed the last software (7.3.0) but it is still bugged like the 7.2.1
Here's a photo so you can see the problem.
at the last image you can see if I click UPDATE , it open the update windows but it write on command line "UPDATE, 6" so is it bugged??post-9119-0-02643500-1331997788.jpg
Can you go into SETUP > DESK SETUP > Event Monitor and see if anything gets displayed in there?
To get out, you will need to either plug in a USB mouse, or restart the desk
Jon Hole
