is there a way I can instrust a stack not to track effects? There is nothing worse than having moving heads whirl around their movement chase whilst blacked out for fifteen cues ahead of the actual cue the chase happens in.
I know that you can put in 'block' cues for moments like this, but in general I NEVER want an effect like that to track ahead because my geriatric old movers are pretty noisy.
I've added this as an issue to look into, with Issue ID ZOS-4410.
For now, go into the previous cue, change 'size' to 0 and ensure it's tagged, and then update the cue (this will work so long as you are in Tracking Mode and don't have Smart Tag on).
