Moving light - colour flickers between colour changes
hansdev
Good day. I'm using two Elation Power Spot 250 and 3 High End Studio Color 250. When I'm finally done programming my sequence for a song, I adjust the LTP Fade to "0". I would assume this would give me a quick transition from one memory to the next. I still have a slight visibility of the light going say from blue to red. How can I make the transition so they are not noticeable. Thanks.
Hans Devouassoux
Capital Community Church
As your colour wheels move your going to see it! unless you set your units to dark while moving, in which case the shutter will close while the colour wheels move or your unit repositions.
The only way out of it is to use some other unit ie pars as fills while the heads change colour. :(
