kim@moltved.dk Posted February 18, 2012 Report Posted February 18, 2012 Hi I can't clear a memory step or change it! It is step nr. 512. Try to load the show on the PhantomJester it is the same problem. No problem program steb before or after. MVH Kim Quote
Jon Hole Posted February 20, 2012 Report Posted February 20, 2012 Hi Kim, I've sent this to our software team to look into, as we've not seen this before!!! Did this memory used to be a chase, which you've deleted the other steps in? Regards, Quote Jon Hole Global Product Manager, Systems and Control
kim@moltved.dk Posted February 21, 2012 Author Report Posted February 21, 2012 Hi Yes it is a chase, that I try delet. I not record the color right, then I try to delete it, i delete all the step. But can't delete the step. BR. Kim Quote
Jon Hole Posted March 6, 2012 Report Posted March 6, 2012 PM sent Quote Jon Hole Global Product Manager, Systems and Control
