Ian Newton Posted February 13, 2012 Report Posted February 13, 2012 I have a Jester 12/24 R1 running the latest update V3.4, this desk had started displaying the following error up power up. Error 002 Bad product ID Data 253 count 004 I can clear the desk by resetting via the master mode but the program memory is obviously lost and requires loading again each time the system is powered up. 1. has anyone a similar experience with this jester model? 2. is there is a more permanent solution that will return the board to 'normal' ? Quote
Jon Hole Posted February 14, 2012 Report Posted February 14, 2012 Hi Ian, Are you sure it's Error 002 and not 003? Sounds to me like the internal battery has died. They are very easy and cheap to replace. You need to get a CR2032 cell battery, which are available in most stores. You then need to open up the console, and the battery is clipped in on the main board, which is attached to the bottom tray of metal work. Best Regards, Quote Jon Hole linkedin.com/in/jonhole
Ian Newton Posted February 17, 2012 Author Report Posted February 17, 2012 Jon Thank you and yes it was 002 the first time I recorded the error since then I have seen 003 and a varity of Data counts. The board we have is a rack mounted model in a flight case, removal from the flight case looks straight forward however, I would prefer to work to a maintenance diagram when disassembling equipment I am not familiar with. Would you happen to know if there is an assembly drawing I can get a copy of so I can avoid removing screws uneccessarily? thanks again Quote
Jon Hole Posted February 17, 2012 Report Posted February 17, 2012 Hi Ian, Give our Service Manager, Keith Rogers, an email - he'll be able to provide you with documents. His email is keith.rogers@cooperindustries.com Regards, Quote Jon Hole linkedin.com/in/jonhole
Ian Newton Posted February 24, 2012 Author Report Posted February 24, 2012 Jon As the board was no going to be used for a week I decided to have a look anyway, I was relieved to find how simple the operation was. A new battery and we are back to the normal operation. I shall still contact Kieth Rodger as suggested as it will be useful to have a diagram to keep with the boards document for who ever gets this task in the future.Perhaps I will find out why there is no mention of the battery in the manual, or did I miss it? Thank you for your help Regards Quote
