burnt phingaz Posted January 24, 2012 Report Posted January 24, 2012 Hi, I'm having problems trying to update ORB with a new fixture.. I have gft23 on a USB stick, I have extracted from the .zip file so it shows in the main window. ORB can see the stick but not the file.. Is this the format of the USB (FAT32), or is it something else? Software update? (I'd rather not have to do this immediately as there is a show on there - although I will if I need to, and obviously its backed up.. thanks Paul Quote
Jon Hole Posted January 24, 2012 Report Posted January 24, 2012 Are you using SETUP > FILES > Update Fixture Files? Quote Jon Hole linkedin.com/in/jonhole
Kirkup_xp Posted January 24, 2012 Report Posted January 24, 2012 Hi Burnt Phingaz, If your desk is running version 7.2 software, you will already have gft23 installed - this is done as part of the software upgrade process. Just worth noting this incase you're already up to date Quote Peter Kirkup
