crunchylogic Posted January 4, 2012 Report Posted January 4, 2012 Hey there Zero88 Hope your new year is going well! Just having an issue an installation we just did out in Munich with a few 24 channel chili dimmers and a chili rs232 node. Trying to control the dimmers from the Crestron AV2 processor hooked up through an RS232 to the Chili RS232 node to the RJ 12 to the RJ12 on the chilli dimmer and I cant get any messages back or affect the dimmers at all.. Im @ 9800, 8, 1, n and have the chilinet enabled and dimmer no.s correct.. not sure what to do. Any assistance is appreciated! Quote
Franck Posted January 4, 2012 Report Posted January 4, 2012 Send me your contact details please. ftiesing@zero88.com Quote
schizofrenia Posted May 10, 2014 Report Posted May 10, 2014 Hi there, I'm having the same problems. I'm Using an AMX NI-3000 with a Chili PRO 12-10i + RCD. Connected my chilinetwork as following: Dimmer (120 Ohm)> RJ12 > RS232 Node > RJ12 > Chili control panel 7 Button > 120 Ohm When i push a button on the control panel the dimmer recalls the Memory. But when i send a command over the AMX, I get none RX back and nothing happens on the Dimmer. The green LED on the NODE flashes, The Red LED does not light up at all. What is the problem, i'm trying for more then a week now to get it to work.... thanks Quote
KWR88 Posted May 12, 2014 Report Posted May 12, 2014 can you pm me on the address below to take this further. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
