Aniaki Posted December 6, 2011 Report Posted December 6, 2011 hi, my Leap Frog 48 is on 7.1 version. in the manual : Press the SUBMASTERS key to display the Submasters Window. Select the submaster tobe edited' date=' then press the LOAD key. The Load Options Window is displayed on the monitor: Select the [OK'] button to load the submaster into the programmer. Adjust the levels of the dimmer channels as required using the preset faders. Adjust the levels of the fixture parameters as required using the MFKs and control wheels. Press the UPDATE key. The Update Options Window is displayed on the monitor. Set the update options as required and then select the [OK] button to complete the edit. Ok, but when i move a fader to change level of my fixture, any change ? i don't understand ? For example, in my submaster 1/2, i want change the level of my Channel 2, 80% to 60% i select SUBMASTER 1/2 i press LOAD and OK i adjust on fader 2 (Channel 2) any change... i press UPDATE any change... i don't understand. Thks for your help Quote
Jon Hole Posted December 12, 2011 Report Posted December 12, 2011 If channel 2's fader was below 80%, you will have to 'catch' the channel... which means taking the fader to or above the value it was at (80%) and then bring it back down to 60%. Hopefully this will work for you. Quote Jon Hole Global Product Manager, Systems and Control
Aniaki Posted December 12, 2011 Author Report Posted December 12, 2011 sorry, but i don't understand ? Quote
Aniaki Posted December 28, 2011 Author Report Posted December 28, 2011 ...which means taking the fader to or above the value it was at (80%) and then bring it back down to 60% ok, but any change ? For example, in my submaster 1/2, i want change the level of my Channel 2, 80% to 60% i select SUBMASTER 1/2 i press LOAD and OK i adjust on fader 2 (Channel 2) any change... i press UPDATE any change... Quote
Jon Hole Posted December 29, 2011 Report Posted December 29, 2011 When you press Load, what percentage is the physical fader at for channel 2? If it's below the 80% that it's programmed at in Submaster 1/2, you need to physically take the fader to this percentage (or above), and then bring it back down to 60%. So, press LOAD and OK Take fader 2 to 100% and then to 60% You should see that channel change Quote Jon Hole Global Product Manager, Systems and Control
