glenn Posted December 3, 2011 Report Posted December 3, 2011 Hey ndo I sey up my Leap Frog to be a play back wing Glenn Quote
Jon Hole Posted December 12, 2011 Report Posted December 12, 2011 The Leap Frog 48 can have up to 30 submasters per page. Go to SETUP > Desk Setup > Inputs and change 'Maximum Submasters per page' to '30'. You can then go and give each submaster a DMX address... which is the address patched to the fader of your 'playback wing' Quote Jon Hole linkedin.com/in/jonhole
glenn Posted December 29, 2011 Author Report Posted December 29, 2011 Thanks for the repley. I just need to clearafy. I have a leap frog and a leap frog 48. I would like to use the leap frog as a play back wing. One which console do I up 30 max submasters. Will i be useing the submasters or the dimmer faders on the leap frog desk. Glenn Quote
Jon Hole Posted December 29, 2011 Report Posted December 29, 2011 You setup the submasters on the Leap Frog 48 as explained above, plug the Leap Frog into the DMX IN of the Leap Frog 48, and then use channels 1 - 48 of the Leap Frog as your playback wing (make sure you reset the Leap Frog so it has a 1-to-1 DMX patch) Quote Jon Hole linkedin.com/in/jonhole
CBMatt Posted February 1, 2012 Report Posted February 1, 2012 So then you can take any DMX console with patchable faders and use it as a wing for the LF48? What about the flash buttons? Would others respond the same way as the ones on the LF48? Could I still run cue lists from this "wing"? Quote
Jon Hole Posted February 2, 2012 Report Posted February 2, 2012 Hi CBMatt, Yes any DMX desk will work as a wing for the LF48, with upto 30 submasters per page. There are already 10 submasters on the LF48, so you have another 20 available. If you wish, you can have all thirty on the wing, and the first 10 will be identical to the 10 on the console itself. The flash buttons will work as they do on the console, with the desk taking the related submaster to 100%. The console recognises the sudden 'snap' to 100%, and so will select that submaster, just like the flash buttons on the console itself do. You can run a cue list from the 'wing', but obviously channel 1 on the 'wing' will be affecting submaster 1 on the console itself. Quote Jon Hole linkedin.com/in/jonhole
