A request from several LDs working for me.
Would it be possible for the submaster flash button lights to also show which submasters contain states?
The lights could be on to show programmed submasters and then flash to off for held submasters.
Would anyone else like this feature? Any other suggestions?
Dave B
  • 5 months later...
Dave B
The lights in the submaster flash buttons are currently used to indicate the following:
Light On - when submaster is fading up or down.
Light Flashing - when submaster is outputting data from a different page (page overlay).
Yep! sounds good to me.
Also to be able to see "CLEARLY" what channel numbers were saved to that sub. :idea:
The easiest way to see what generic channels are programmed into a submasters channel data or its transferred memory is to select the required submaster and press the Preview button.
