singingtooth Posted November 28, 2011 Report Posted November 28, 2011 Hi guys I have recently bought a few Lanta Lasers: Lanta Blazar Sapphire 500 http://lantalighting.com/assets/handbook/J84794%20Blazar%20Sapphire%20500%20Handbook.pdf Lanta Blazar UV Pink http://www.djkit.com/documents/J64989%20Blazar%20UV%20Pink%20Handbook.pdf Lanta Quasar G50 Micro http://www.etsnet.co.uk/wp-content/uploads/2010/10/Quasar-Micro-G50-Handbook.pdf I'm using the fixture type editor but need some help. I think on all the lasers, channel 1 (Operations mode) is the primary dimmer (Brightness) The rest of the channels, do I use Beamshape for all of them? I've attached what I've done but would really appreciate someone having a look at the file to see if I've done it right. Cheers all Lanta.ift Quote
singingtooth Posted January 9, 2012 Author Report Posted January 9, 2012 Hi all Can anyone help me with this topic? Many thanks. Quote
Jon Hole Posted January 13, 2012 Report Posted January 13, 2012 Hi, It's up to you which parameters you put into each attribute. However, putting them all into BeamShape will make programming quite slow for you, so I've made a few changes: Blazar Sapphire 500 / Blazar UV Pink - I've put HMotion, VMotion, HStretch, VStretch and Rotate into Position. This means there are then only two pages (2 x 3) of parameters in the Beamshape attribute, which will make programming much easier. Quasar G50 - I've done very similar, putting X/Y/Z Rotate and H/V Motion within the Position attribute, and left the others inside Beamshape. I hope this is helpful Lanta (2).ift Quote Jon Hole linkedin.com/in/jonhole
