Trying to Add a "Home made fixture" in the Phantom Jester using a usb key...does'nt work !
Screen just say "no file found"
Any way to use our "home made fixture" in the Phantom Jester (v3.1)
Tkx
Best Regards
Tested this out and do not seem to have an issue loading fixtures into the phantom desk.
Check the path to where it will search is correct in the settings menu.
If you had it mapped to the USB port when a USB drive is plugged in make sure it is the same port the USB is generating when you plug it in now or update the path to drive match it.
Keith Rogers
