Sven76 Posted July 27, 2011 Report Posted July 27, 2011 Hello@all! In a few weeks, I will have to do a show with 4 ROBE Robin 300 Spot Classic on a Leap Frog 96. Ans because I didn't find any library for this lamp, I decidet to build it on my own (for the first time ever). I luckiely get up everythin running - except the Macros! This is what happens: I press "add Macro". I Name it "Lamp On" (for example). I press "Add step", choose "Set Channel Level" on Channel "Lmp/Res" and set it on Level 135. Then I add a second step with "Wait" and 6000 ms. Now the problem: In "Edit Macro" I can see theese 2 steps. But as I press "OK", I only see the name of the macro and "0" Commands behind it in the "Macros" tab :-( The second problem is, that the Editor does'nt store the Stage Data to this fixture. I can edit it and everything looks fin - but after I save it, close the editor and load it again - there is "no Stage Data" again :-( I'm using the Editor in Version 0.0.12.120 (which was a download link on the orb FX to Version 3.5, because I wanted to insert the jpgs of the gobos to the fixture). I hope enybody can help me with that. Kind regards! Sven Quote
Franck Posted July 27, 2011 Report Posted July 27, 2011 Hi Sven, Did you downloaded the latest fixture library? Most fixtures are up to date and Robin's are in as well. http://support.zero88.com/forum/index.php?showtopic=6117 Cheers Franck Quote
Sven76 Posted July 28, 2011 Author Report Posted July 28, 2011 Hello Franck, that was the first thing I tried Unfortunatly, the Robin 300 Spot Classic isn't in there The only "Robins 300" in there are the "Plasma" and the "300E". But those are color-mixers and the 300 spot clasic I have only have a color wheel. Regards Sven Quote
Jon Hole Posted August 8, 2011 Report Posted August 8, 2011 Hi Sven, Could you email me the fixture you have made and I will look at fixing it for you, and adding it into our next release of the Library. Many Thanks Quote Jon Hole linkedin.com/in/jonhole
Sven76 Posted August 26, 2011 Author Report Posted August 26, 2011 Hello Jon, I'd like to ask you, if my email arrived and if you were able to use them to build a new fixture out of it? Kind regards Sven Quote
Sven76 Posted September 9, 2011 Author Report Posted September 9, 2011 Hello@all, does anybody know something new about this? It's getting realy ergent for me. Will there be a fix to the library editor? Or am I the only one with this problem? Kind regards Sven Quote
Jon Hole Posted September 10, 2011 Report Posted September 10, 2011 Hi Sven, Sorry for the slow response. I don't recall getting your email, but I will go back and check through my past emails. Which date did you send it on? Jon Quote Jon Hole linkedin.com/in/jonhole
Sven76 Posted September 10, 2011 Author Report Posted September 10, 2011 Hi Jon, I have sent it on August, 16th. But I tried to send it again right now, so that you should have it in your Mailbox now. If not, please let me know! Thx for your help! Kind regards Sven Quote
Sven76 Posted September 13, 2011 Author Report Posted September 13, 2011 Hi@all, I'm realy, realy, realy sorry, but I have to ask again: Is there anythin new about my problem? Kind regards Sven Kempf Quote
Jon Hole Posted September 16, 2011 Report Posted September 16, 2011 Hi Sven, I'm looking into it at the moment. We have a backlog of fixture requests from over PLASA. Quote Jon Hole linkedin.com/in/jonhole
Jon Hole Posted October 17, 2011 Report Posted October 17, 2011 This topic is now being dealt with off-forum Quote Jon Hole linkedin.com/in/jonhole
