Can someone explain why color attributes are only triggered at 5% on submasters ? I find that with LED's because they're not very linear you have a visible brightness level as the submaster comes up with the wrong color (if a previous sub you used had a different colour) until the color attributes are triggered and the color change is then very noticeable. I'd like to change this behaviour - is that possible ? However I'm also thinking there must be a good reason for it being set like that which I'd like to understand as well !
Thanks,
John.
P.S have searched the forums and seen this behaviour mentioned before, but no explanation as to why or whether it can be changed.
  • 2 weeks later...
