johng Posted July 26, 2011 Report Posted July 26, 2011 Can someone explain why color attributes are only triggered at 5% on submasters ? I find that with LED's because they're not very linear you have a visible brightness level as the submaster comes up with the wrong color (if a previous sub you used had a different colour) until the color attributes are triggered and the color change is then very noticeable. I'd like to change this behaviour - is that possible ? However I'm also thinking there must be a good reason for it being set like that which I'd like to understand as well ! Thanks, John. P.S have searched the forums and seen this behaviour mentioned before, but no explanation as to why or whether it can be changed. Quote
Jon Hole Posted August 8, 2011 Report Posted August 8, 2011 Hi John, There's currently no way to change the 5% trigger value on the Jester ML. It's set to 5% to ensure that Submasters don't get activated automatically due to the tolerances that can be seen overtime on the fader components. Quote Jon Hole linkedin.com/in/jonhole
