A few minutes ago I installed the new version of ZeroOS 7 on my LeapFrog 48.
The the desktops and the filter library are great!
Unfortunately it is now impossible to put the groups and effect windows on the screen by pressing (and holding) shift + the groups or effect button.
Instead of the effect window the position window appears.
It does not work on my Leapfrog and it doesn't work on the Phantom as well.
Using the IOS Remote App (IPod touch) it worked - both windows are appearing there.
Is it a bug or is there a reason why you removed this feature?
Edit: Just figured out that is not that critical as I thought.
I still have the option to access the windows by using the path output -> other windows -> Effect or groups.
Hi chw,
Thanks for spotting this one - we hadn't actually noticed it during testing, it's obviously something that got broken in the new software.
I've added it as a bug report onto our system - reference ZOS-3759 - and it will be fixed in the next release.
As you say, for now, the work around is to use the Other Windows button.
Sorry about this bug, I hope it doesn't cause you too many problems.
Peter
Peter Kirkup
Hi diver1976,
If you open the Output Window (with the Outputs button on the front panel) and then select the Other Windows drop down in the top left, you can open the Effects Window from there.
I hope this helps,
Peter
Peter Kirkup
  • 2 weeks later...
Hi Peter,
what you Timewindow for this UpdateRelease?!
Today or Tomorrow Morning?!
Tomorrow at 10.00 am i will start with my job!
Have you tested the 7.0 ?!
When i will start to program my desk, i open the 4 palettewindows.
That´s my start.
I can´t understand that a new software have so a basic BUG!!!
BR
Martin
