Pablo Posted June 6, 2011 Report Posted June 6, 2011 I'm using a jester ml 12/24 with some par led (6ch: Red,Green,Blue,Strobe,Macro,Dimmer), i would use 3 submaster as rgb control: 1 red, 1 blue, 1 green. and make every combination during the live show. But color attributes are triggered at 5% and they operate in LTP mode (i would control intensity and turn off colors just moving submasters's fader to 0%) Is there some solution? (i'm sorry, i don't speak english) Thanks a lot Pablo Quote
Kirkup_xp Posted June 8, 2011 Report Posted June 8, 2011 Hi Pablo Unfortunately the Jester ML series do not provide proportional control over the attributes like you described. One option would be to patch the fixtures as simple dimmers instead of RGB devices (you'll need 4 buttons per fixture, or 4 faders) and then program each submaster as follows: 1 - Red and Dimmer at full 2 - Green and Dimmer at full 3 - Blue and Dimmer at full I hope that this helps, Peter Quote Peter Kirkup
