DickM Posted January 26, 2004 Report Posted January 26, 2004 May seem like a silly question, but is there any way of getting the Phantom Frog to load a show from anywhere other than a floppy drive? My PC doesn't have a floppy, but I've got my show file that I emailed to myself from another machine that does, so the file is now on my hard-drive. But I can't load it up because the Phantom seems to only search for a floppy... and fails to find one If it can't currently be done, can I ask for it to be considered for the next release please :?: Cheers, Dick. Quote
Laubfrosch Posted January 27, 2004 Report Posted January 27, 2004 Hi Dick, not a silly one!!! I checked for any inf-File which provides an edit option..... :cry: NO WAY! cheers Sven Quote Sven Paulsen Klangfarbe Vienna
Oscar Palmkes Posted January 27, 2004 Report Posted January 27, 2004 there is a way ... Its not an easy way if you are not good with PC's i have the same problem here, You can make a virtual diskdrive, it makes a station of a directory you choice. I use "Daemon", its a small program just 400kB but it works Its for free so if you search google ... Quote
DickM Posted January 27, 2004 Author Report Posted January 27, 2004 It's OK... I found a way to do it using standard Windows-XP - using the Computer Management tool (in the Administrative Tools on the Control Panel) I renamed my removable USB memory drive to be drive-A. Then copied the show file from the hard-drive onto that. Because this is now the A-drive, the Phantom Frog then thinks it's a floppy and quite happily loads the show! It might be an idea to still consider a 'load from anywhere' function for a future release of the Phantom Frog though, as some people will not have another drive they can rename, and even if they have, they might not be happy to mess around with their computer configuration like this. Cheers, Dick. Quote
GLX Posted January 27, 2004 Report Posted January 27, 2004 Why not install a floppy drive on your pc? they cost about 15euro the ribbon should be knockin around inside your pc, and the power supply has loads of juice to run it. Quote
DickM Posted January 28, 2004 Author Report Posted January 28, 2004 Why not install a floppy drive on your pc? they cost about 15euro the ribbon should be knockin around inside your pc, and the power supply has loads of juice to run it. True, I could install one, but in the two years I've had this PC this is the first time I've ever needed one. I normally move any data around either using my home LAN or a 64Mb USB memory drive - a floppy is soooo 20th Century :wink: It won't be long before th Frog's are shipped with USB ports I'm sure :idea: Cheers, Dick Quote
Haytech Posted January 28, 2004 Report Posted January 28, 2004 a floppy is soooo 20th Century lol seen some big disk´s before Please add to our frogs with next update a USB Port, Harddisk for loads of memorys and DVD Rom to see some cool Videos on a boring venue Quote Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
Paul Posted February 27, 2004 Report Posted February 27, 2004 Have a look at Phantom Frog 9.2 (CLICK HERE). You should also find the transfer buttons now the right way round, and the faders will remember where you left them. edit: fixed link Quote
DickM Posted March 11, 2004 Author Report Posted March 11, 2004 Have a look at Phantom Frog 9.2 I will take a look, but I guess trying to edit a show with v9.2 that was created on a hired desk that's supplied with v7 is not a good idea! When the hire co update their software, I'll update my copy of the Phantom! Quote
K-Nine Posted March 11, 2004 Report Posted March 11, 2004 You should be able to edit a show created with version 7 software on the latest Phantom Frog (9.2), without any problems. Any information that is not present in the older show file should be set to default values automatically (eg number of shots on chase memories, new submaster/SX defaults etc.) As long as you don't edit any parameters which are new in version 9 software, then you should also be able to reload your show file into a desk with version 7 software, although obviously it would be better to update the desk software as well Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
lightbulb789 Posted August 30, 2004 Report Posted August 30, 2004 Why not install a floppy drive on your pc? they cost about 15euro the ribbon should be knockin around inside your pc, and the power supply has loads of juice to run it. True, I could install one, but in the two years I've had this PC this is the first time I've ever needed one. I normally move any data around either using my home LAN or a 64Mb USB memory drive - a floppy is soooo 20th Century :wink: It won't be long before th Frog's are shipped with USB ports I'm sure :idea: Cheers, Dick Floppy drives only cost between £5-10 and there always handy to have around its worth having one. Quote
sparks Posted August 31, 2004 Report Posted August 31, 2004 I may have missed something but i sure i remember changing the floppy path on start up of phantom frog so that it read from hard drive. yaeh under where you select type of desk frog, fat frog etc is a box labeled floppy path hit the browse button and point froggy whereever you like. Barry Quote
DickM Posted September 1, 2004 Author Report Posted September 1, 2004 I may have missed something but i sure i remember changing the floppy path on start up of phantom frog so that it read from hard drive. yaeh under where you select type of desk frog, fat frog etc is a box labeled floppy path hit the browse button and point froggy whereever you like. Barry Not on the version I was using there wasn't, but then things may have changed since then. But thanks for the tip - next time I need to use it, I'll download the latest version with this handy new feature. DickM Quote
Pipo Posted September 1, 2004 Report Posted September 1, 2004 yaeh under where you select type of desk frog, fat frog etc is a box labeled floppy path hit the browse button and point froggy whereever you like. Can't seem to find it, which version do you use? Quote Den Pipo Pro Light Design
K-Nine Posted September 1, 2004 Report Posted September 1, 2004 The functionality that allows you to choose which drive to load shows from can be found on version 9.2 of the Phantom Frog. When you start up Phantom Frog, select the Desk Type (eg Fat Frog) and then click on the Browse button. You then get a window asking you to insert a disk into drive A. Click on the Cancel button in this window. You then get a Browse for Folder window which allows you to select a drive where you have stored your show files. Select the required drive and click on the OK button. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Pipo Posted September 1, 2004 Report Posted September 1, 2004 correct, had the old and new version on my laptop. Sorry Quote Den Pipo Pro Light Design
DickM Posted September 1, 2004 Author Report Posted September 1, 2004 The functionality that allows you to choose which drive to load shows from can be found on version 9.2 of the Phantom Frog. Thanks for the confirmation K-Nine. Just goes to prove what a great place this is to post your questions/problems... not only do you invariably get useful suggestions from fellow members, it may even result in an improvement to the product too DickM Quote
