Jake Posted May 27, 2011 Report Share Posted May 27, 2011 HI I've got two Betapack 2 with DMX fitted at are at the moment broken (i think) here the problem When i say fade channel 1 up it doesn't work on both sockets but if i turn them off and then turn them back on again same thing happens even with the test switch this happens. after a few atemps it does turn on but it flickers and doesn't go full power. Any ideas? Thanks Jake Quote Link to comment Share on other sites More sharing options...
KWR88 Posted May 31, 2011 Report Share Posted May 31, 2011 Think you also posted this on the Blueroom as well. If yes then you have sorted the problem from what I read. If not, or as I replied on the Blueroom PM on the address below. Quote Regards, Keith Rogers keith.rogers@signify.com DD: +44 (0) 1633 833 101. Link to comment Share on other sites More sharing options...
rafteryd Posted July 27, 2013 Report Share Posted July 27, 2013 Hey, Im having problems with my beta2s I have 2 in a rack and both of them blink to off and back to original valve just once or twice then holds then if you change the value it will go to the set value then bink off then to set value but only on ch1 on both packs no other ch... any thoughts? Dave Run on 3phz and dmx Quote Link to comment Share on other sites More sharing options...
iank99 Posted August 2, 2013 Report Share Posted August 2, 2013 When you say "both of them blink to off and back to original valve just once or twice then holds" - is that when you first power the racks up or when they've been powered and then a desk connected and DMX sent to them? Is it the front panel LED's that blink or lanterns/loads you have connected to channels - I'm trying to establish whether the rack is responding to DMX and controlling power or just doing nothing. I suspect that you'll end up taking the racks to a Zero88 service centre to be looked at but before you do - ensure that they're comfortable with repairing BetaPack 2's. Beta 2's were discontinued a while ago and some people aren't that happy with repairing them and would rather repair Beta 1's Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
KWR88 Posted August 6, 2013 Report Share Posted August 6, 2013 Could you PM me PM on the address below with the unit serial numbers. Also what DMX addresses you are using and the type of desk as well. Quote Regards, Keith Rogers keith.rogers@signify.com DD: +44 (0) 1633 833 101. Link to comment Share on other sites More sharing options...
