LED on the channel flash
cwko
With the old model Sirius 24 or 48, the green channel light above the channel flash button always show the actual output of each channel (i.e. the signal sent to the dimmers, and hence to the lanterns), so without using the external monitor, we still can monitor the output level. For Jester, can the LED on the channel flash buttons do the same jobs?
any help would be appreciated.
Cheers
Godrevy
No the jester does not have this function, the LEDS are used to indicate other things to do with submaster and channel levels when editing etc.
The channel output level display is only on the monitor screen.
Keith Rogers
To give you an idea of what the LEDs do...
Flashing LED tells you that the fader is not at the same level as the lantern whilst in 'Program' (for example, when editing a cue).
A solid LED along the bottom preset whilst in 'Run' means that there is a submaster programmed onto that channel.
Jon Hole
