Carwyn Posted April 26, 2011 Report Posted April 26, 2011 HI could anyone tell me what the trigger comand would be for 1. triger the go button over art net or go to q? 2 submaster 1 up or 1 down if this is possible Quote
Jon Hole Posted May 3, 2011 Report Posted May 3, 2011 Hi Carwyn, You can't send commands over ArtNet to trigger cues or submasters. What are you trying to achieve? Maybe we can find another way around this? Quote Jon Hole Global Product Manager, Systems and Control
Carwyn Posted May 4, 2011 Author Report Posted May 4, 2011 what im trying to achieve is to take channels up and down on request Quote
Jon Hole Posted May 4, 2011 Report Posted May 4, 2011 From which device? Quote Jon Hole Global Product Manager, Systems and Control
Jon Hole Posted May 9, 2011 Report Posted May 9, 2011 Could you go into more detail about what you would like to happen and when? Maybe you could explain your set up too? Thank You Quote Jon Hole Global Product Manager, Systems and Control
Carwyn Posted May 19, 2011 Author Report Posted May 19, 2011 when the film starts we need a command to be sent to the lighting desk to dim the lights a bit whil adverts are on then possibly another trigger to take the lights compleately off then when the credits start lights come up a bit then at the end of the film another trigger to turn the liights backk on again Quote
Jon Hole Posted May 20, 2011 Report Posted May 20, 2011 These commands wouldn't be sent from the projector, but from whatever your playback device is. Are you using DVD, Video, Hard Disk? If you can give me a product name / model number of your playback device we might be able to find a solution for you. Many Thanks Quote Jon Hole Global Product Manager, Systems and Control
