OK, fairly new Fat Frog user here. I am running into a challenge when playing back scenes on submasters that contain moving lights. A little background first: I am running software 10.12,and the console is setup in Partial. When I program a static scene onto a submaster that includes a moving light it will play it back fine except it will not turn off when the submaster is lowered. I know that the attributes are programmed on LTP and intensity is HTP and I am fine with that but why wont it turn off. Any suggestions or expert advice would be awesome.
Thanks
Dan
Daniel Glass
Lights4Rent
  • 2 weeks later...
What heads are you using, and which mode etc.
Some heads combine a dimmer and shutter on the same channel, in this case we se them as LTP channels as default, think mini mac profiles.
PM me on the address below for more information.
Keith Rogers
