Ian_SDC Posted March 24, 2011 Report Share Posted March 24, 2011 Betapack 2 was working fine till on DMX until someone plugged a Zero 88 analogue board in. Now wehn powered up no lights on the front. Could it be they had the Voltage to pin 7 set to the wrong version and it has burnt something out. Or is it just a fuse inside somewhere Quote Link to comment Share on other sites More sharing options...
KWR88 Posted March 24, 2011 Report Share Posted March 24, 2011 Yes there is an internal fuse. It is a 50mA T type 5mm by 20mm glass fuse located on the triac PCB between the transformer and the live input from phase 1. You can use an 80mA if you can't loacate a 50 but would not go higher than this. To loacte the fuse: Isolate the pack from the mains supply. Remove the lid of the unit. With the front of the pack towards you the transfomer is on the LHS of the PCB. Quote Regards, Keith Rogers keith.rogers@signify.com DD: +44 (0) 1633 833 101. Link to comment Share on other sites More sharing options...
