pcollins666 Posted March 7, 2011 Report Posted March 7, 2011 On several occasions I have wanted to delete the memory stack but keep the programmed submasters. In Set up mode you do not get the option to delete one or the other, only both. Only way is to delete each memory one by one. Could this option be made available in the next software update? It's not a big issue but would be a 'nice to have' if it was easy to add! Cheers, John Quote
Jon Hole Posted March 8, 2011 Report Posted March 8, 2011 Hi John, Thanks for the feedback. I have added this to our database as issue JES-3253. Many Thanks Quote Jon Hole linkedin.com/in/jonhole
