pierotec Posted February 23, 2011 Report Posted February 23, 2011 Hi, I have a curiosity , as you can distinguish externally, an Frog2 old hardware by an model with new hardware thanks for answer Piero Quote
Jon Hole Posted February 24, 2011 Report Posted February 24, 2011 Hi Piero, The old FROG 2 hardware has 2 USB ports on the front, whereas the new hardware only has the one. There are a lot of changes to the layout of the back panel too (such as more USB ports etc), but this is the easiest to see! Hope this helps, Quote Jon Hole Global Product Manager, Systems and Control
