rmberg Posted February 15, 2011 Report Posted February 15, 2011 Hi From one day to another my lightmaster XLS doesn't give any dmx output to channel 13-24. Is there a simple answer to this? Thanks , Ruud Quote
KWR88 Posted February 16, 2011 Report Posted February 16, 2011 As long as the faders are still bringing the green LED on when you take them up, then the only cause of this would be corruption of the soft patch on the desk. Simplest thing to do is reset the patch back to 1 to 1 by using the super user reset (RS) option. If this then happens again it may indicate the internal battery is starting to fail. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
rmberg Posted February 19, 2011 Author Report Posted February 19, 2011 Hi thanks for youer quick answer. The problem is double : no output from 13- 24. I've set the patch back 1 to 1 by patching each of the channels seperate. And it works. I've changed the battery, on your advise from other forum members. The second problem is that the red led lights on the right don't work, so I can't see what I'm doing in the super user or chase or go-button. In another reply to another member you wrote : Second I would also try removing the 63b05 AcAI as this can stop the displays from working by dragging down the address lines and clock etc.. The problem is that I can't find a 63b05 ACAI on my board. Could it be another number on my board? Tnanx, ruud Quote
