Hello, as the desk is a tracking desk, is there any possibility it is able to fully track each step taken so that a press of an undo button on a MFK say, would simply undo the last step?
Is this achievable?
Hi Techbppac,
Thank's for your feedback and suggestions.
That's not quite how tracking works, so we couldn't quite implement it like that. However, having true 'undo' functionality is listed as a future feature to look into implementing.
At the moment, you can use backspace to go back into the command line and undo each change you have done, step-by-step, up until you last pressed record or cleared the command line.
