Just started doing lighting for a theater tour. Band have a Leap Frog 96. Have previously used Fat Frog so am now trying to get to grips with this. Previously someone has deleted all Universe 1 dimmer patches and just created a few blocks obviously corresponding to an in house set of dimmers. These are all upwards of DMX 300 or so. All I want to do is clear these patches and create 96 new dimmer channels. Is there any quick way to do this without clearing fixture settings as well, or am I destined to create each one individually?
Also, have a fixture with no shutter parameter, rather, uses intensity 130 to 200 to strobe. Looking at fixture editor, can I edit the profile and move dimmer control over to beamshape instead of position for easier management of pallets?
HI Triska
You can select multiple locations in the Patch Wizard by pressing and holding the first and tapping the last location when selecting the destination. This will patch multiple fixtures at once - upto 96 for all 96 faders if needed.
You can indeed move Intensity into Beamshape using the fixture editor, just as you described.
I hope this helps, please let me know if you need any more help with the desk.
Peter
