Dodgy fade on Zero 88 desk
Zulu
First post here. . . I have well used Zero 88 desk, and have started seeing a problem with fade: when setting for a 5 second (say) fade, the next cue just jumps to full virtually instantly. Not good for the production. Don't know anything about it, but could it be the knob is waring out. Is it fixable? Otherwise this trusty old desk works great
thanks , Zulu
Hi Zulu,
Welcome to the Zero 88 support forums!
As jonasprawer suggests, without knowing which desk you have this is a little but harder!
For best results, you should post this in the relevant forum. At the bottom of the main forum page (http://support.zero88.com/forum) you will see a section for each of our current products, as well as sections for our past, discontinued product.
However, if you just reply letting us know which console you have, I will move this post to where it needs to be!
Many Thanks,
Jon Hole
Yes, there is a click when switching from "manual" position to the timed fades positions. This is normal.
I am not at the theatre at present, but I can retrieve the desk. Is it possible to do testing remote from the lighting rig, eg at home ?
The problem is intermittent, but seems to be worse at the position I use most frequently, around the 3 - 4 second mark.
ta, Zulu.
