paullaverick Posted December 9, 2010 Report Posted December 9, 2010 I am currently trying to remove the autofade knobs from the Level 18 desk, but they won't budge. Is there any technique or way to do this? Also, i think i need at least one new pot for the autofade, where would i get spares from, if they are available? Thanks, Paul Quote
KWR88 Posted December 9, 2010 Report Posted December 9, 2010 Hi Paul, the fade knobs are collet knobs this means that they are held in place by a nut. If you look at the top of the knob you should see that it has a line runing around it you can then lift this part off to get at the nut, from memory it a m8 nut. Replacement pot is order code 4407000 for the older levels, and 4407500 if it the level plus. You need to conact either your local dealer or our customer services team for pricing. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
paullaverick Posted December 9, 2010 Author Report Posted December 9, 2010 Hi. Thanks for the help. The lid looked like it was part of the knob, a little bit dirty, hence the stripping down. Paul Quote
